Blue Diamond Windbreak 7 Pole Sand / Grey Contemporary Stripe Windbreak
£49.99 Inc VAT
Out of stock
Blue Diamond’s windbreaks are fast becoming a caravanning essential; the contemporary ‘7-Poled Sand / Grey Striped Windbreak’ is a contemporary windbreak produced from a heavy-duty lock-stitch polypropylene, designed to provide additional privacy and exceptionally effective deflection of the wind around your awning, tent or simply you. The windbreak canvas is rot-proof and has a 2-year warranty against any manufacturing faults! This accessory incorporates nine soft-wood poles, with a metal spike on one end to easily and securely penetrate the ground, as well as a metal ferule on the other to prevent damage to the pole.
The accessory measures 5ft high x 18ft long (152 x 549cm); it comes complete with everything you need to pitch the windbreak, including an awning channel to attach to the caravan, windbreak clips, steel tips and steel caps. The windbreak comes complete in a Sand / Grey striped colourway for a modern finish.
WB770
Blue Diamond
