Blue Diamond’s windbreaks are fast becoming a caravanning essential; the ‘7-Poled Burgundy/Navy Striped Windbreak’ is a contemporary windbreak produced from a heavy-duty lock-stitch polypropylene, designed to provide additional privacy and exceptionally effective deflection of the wind around your awning, tent or simply you. The windbreak canvas is rot-proof and has a 2-year warranty against any manufacturing faults! This accessory incorporates seven soft-wood poles, with a metal spike on one end to easily and securely penetrate ground, as well as a metal ferule on the other to prevent damage to the pole. The accessory measures 18 foot long and approximately 4ft tall; it comes complete with everything you need to pitch the windbreak, including an awning channel to attach to the caravan, windbreak clips, steel tips and steel caps. The windbreak comes complete in a navy / burgundy striped colourway for a modern finish.
- Provides Privacy & Deflects Wind
- 7 Soft-Wood Poles
- Heavy-Duty Lock-Stitch Polypropylene Material
- Contemporary Navy / Burgundy ‘Striped’ Design
- Metal Spikes for Penetrating Ground
- Metal Caps for Preventing Damage
- Rot-Proof Material
- 2 Year Warranty on Windbreak Canvas
- Includes Awning Channel, Windbreak Clips, Steel Tips and Steel Caps
WB780
Frequently bought together
| Weight | 2.85 lbs |
| Dimensions | 64 × 24 × 14 in |
Blue Diamond
