19MM Socket Caravan Corner Steady Legs Cordless Drill Winder Adaptor
33cm Corner Steady Winder Extension Socket
For winding down the corner steadies on a caravan or motorhome which stabilise and level it when parked up.
This 33cm corner steady extension socket is a 19mm socket forged onto a hexagonal bar which enables even the stiffest of corner steadies to be wound up.
The hexagonal bar prevents the socket slipping in the chuck.
Using this accessory in conjunction with your cordless drill make the lowering and raising of the corner steadies less of a chore.
Strong metal construction
Raise and lower caravan legs with ease
19mm socket
Suitable for all drills
33cm long
19mm socket
33cm long
BJ460
