13 Pin Parking Plug
£2.99 Inc VAT
Only 2 left in stock
SKU: 5060070229737 Categories: , ,
This 13 pin parking plug can be attached to the A frame of a caravan or trailer, to enable safe storage of the 13 pin plug -screws and plug not supplied. When detaching the plug from the towing vehicle, simply insert into the parking plug & twist clockwise to lock in place. This plug assists you to re-align a 13 pin plug and helps prevent any subsequent damage. Inside the parking plug is a gasket seal which prevent any dust or debris from entering the plug when not in use. The parking plug can be fitted to your caravan using the 3 mounting holes.
  • For safe storage of your 13 pin plug
  • Easy to install
  • Helps to re-align pins
  • Prevents dust and dirt entering the plug
  • 3 easy mounting holes
  • Approximate dimensions: 55mm x 25mm
RI704
12810B
Pennine Leisure Supplies
Be the first to review “13 Pin Parking Plug”
13 Pin Parking Plug
£2.99 Inc VAT
